JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Specialized Models
Model Comparison
• Model Comparison Platform Options
Some options in the Model Comparison red triangle menu depend on your data.
Continuous and Categorical Responses
Model Averaging
Makes a new column of the arithmetic mean of the predicted values (for continuous responses) or the predicted.probabilities (for categorical responses).
Continuous Responses
Plot Actual by Predicted
Shows a scatterplot of the actual versus the predicted values. The plots for the different models are overlaid.
Plot Residual by Row
Shows a plot of the residuals by row number. The plots for the different models are overlaid.
Profiler
Shows a profiler for each response based on prediction formula columns in your data. The profilers have a row for each model being compared.
ROC Curve
Shows ROC curves for each level of the response variable. The curves for the different models are overlaid.
AUC Comparison
Provides a comparison of the area under the ROC curve (AUC) from each model. The area under the curve is the indicator of the goodness of fit, with 1 being a perfect fit.
The report includes the following information:
standard errors and confidence intervals for each AUC
standard errors, confidence intervals, and hypothesis tests for the difference between each pair of AUCs
an overall hypothesis test for testing whether all AUCs are equal
Lift Curve
Shows lift curves for each level of the response variable. The curves for the different models are overlaid.
Cum Gains Curve
Shows cumulative gains curves for each level of the response variable. The curves for the different models are overlaid.
Confusion Matrix
Shows confusion matrices for each model. A confusion matrix is a two-way classification of actual and predicted responses. Count and rate confusion matrices are shown. Separate confusion matrices are produced for each level of the Group variable.
If the response has a Profit Matrix column property, then Actual by Decision Count and Actual by Decision Rate matrices are shown beneath the confusion matrices. For details about these matrices, see
Decision Matrix Report
in Partition Models
Profiler
Related Information
ROC Curve
in Partition Models
Lift Curves
in Partition Models
