When the Generate Report for Current Model button is clicked, summary reports are added in two places:
An entry is added to the Model List report. Refer to Model Lists for more details.
An entry is added to the Reports report. Refer to Reports for more details.
The Model List report gives summary statistics and other options for every fitted model. Model List shows an example of the Model List with summaries for three models. Model List Report gives information about the Model List report.
Gives -2xloglikelihood. See Fitting Linear Models.
Gives the corrected Akaike Criterion. See Fitting Linear Models.
Gives the Bayesian Information Criterion. See Fitting Linear Models.
Gives the p-value for a two-sided test for the parameter.
