JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Multivariate Control Charts
• Multivariate Control Chart Overview
Univariate control charts monitor a single process characteristic, whereas multivariate control charts monitor multiple process characteristics. Independent variables can be charted individually, but if the variables are correlated, a multivariate chart is needed to determine whether the process is in control. Multivariate control charts can detect shifts in the mean or the relationship between several related variables.
To construct a multivariate control chart for individual or sub-grouped measurements, first identify a period of time during which the process is stable and capable. Then, using JMP, proceed as follows:
Develop a control chart to verify that the process is stable over this period.
Save the target statistics for this data.
Monitor the on-going process using a control chart based on these saved target statistics.
