Basics of the Report Window
Select the hand tool using the Tools > Grabber option. There are many functions that you can use with the hand tool (also known as the grabber tool) in a report. Here are some examples of how the hand behaves in graphs and plots:
Add Text Item - Opens a window that enables you to add up to six text items. You can select whether the text items appear with a bullet or initially appear hidden. Note: You must click exactly on a hidden text box for the text item to become visible.
Add Outline Item - Open a window that enables you to add a titled outline box. Note: The appended outline box contains a red triangle menu listing the append menu items.
Add Window Reference - Opens a window that enables you to select an open JMP window for adding as a link to the selected outline box.
Add File Reference - Displays the Open Data File window that enables you to select a file for adding as a link to the selected outline box.
Add Directory Reference - Displays the Browse For Folder window that enables you to select a directory for adding as a link to the selected outline box. Note: Links to each file in the selected directory are appended to the outline box.
Add All Open Files - For each file open in JMP, a new outline box is added. It contains a link to the file.
Add URL Reference - Opens the Create Link to URL window that enables you to add a Link Name and URL. The URL reference link is added to the selected outline box.
Add Script Button - Opens the Add Script Button window that enables you to add a named link to the selected outline box. Clicking the added link runs the specified script.
Displays the submenu shown in Outline Box Menu Items Window, which affect all reports at the outline level where they are used:
An alternative way to access these options is to hold down the Alt key and right-click the disclosure button . This displays a window, as shown in Outline Box Menu Items Window, with check boxes for commands and options so that you can select multiple actions at the same time. You can also do the same for the menu under a red triangle menu.
Select the check box in the lower right corner of the windows you want to combine. Select Combine selected windows next to the check box. Or select Window > Arrange Combine Selected Windows.
Select Window > Combine Windows.
On Windows, change the font size that JMP uses in reports and data tables by selecting Window > Font Sizes. Then choose from one of the submenu items:
On Macintosh, select View > Make Text Bigger or View > Make Text Smaller.
