The Fit Curve personality does not require you to specify starting values for parameter estimates or create model formulas. To specify your own starting values and create model formulas, use the more powerful custom Nonlinear personality, which can also fit any nonlinear model. For details, see the Nonlinear Regression with Custom Models section.
