The Display Options sub-menu contains the following options:
Moves the Count, Prob, and Density axes to the left instead of the right.
This option is applicable only if Horizontal Layout is selected.
The Histogram Options sub-menu contains the following options:
This menu contains confidence levels. Select a value that is listed, or select Other to enter your own. JMP computes score confidence intervals.
The Save sub-menu contains the following options:
Creates a new column in the data table called Level <colname>. The level number of each observation corresponds to the histogram bar that contains the observation.
(Use with the Order By option) Creates a new value ordering column property in the data table, reflecting the new order.
