JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Parallel Plots
• Parallel Plot Platform Options
The following table describes the options within the red triangle menu for Parallel Plot.
Show Reversing Checkboxes
Reverses the scale for one or more variables.
Script
This menu contains options that are available to all platforms. They enable you to redo the analysis or save the JSL commands for the analysis to a window or a file. For more information, see
Using JMP
For details about the context menu options that appear when you right-click on a parallel plot, see
Using JMP
