JMP customizations are stored in <username>/Library/Application Support/JMP/<version>/usercust.jmpcust.
Select View > Customize Menus.
Select File > Open.
Press Control and then select Add New Menu Item after.
Type What is the Current Time? in the New Item Label box.
Select Run JSL in this file: and select Library/Application Support/JMP/12/Scripts/timeAnnouncer.jsl.
6.
7.
Select File > What is the Current Time?.
In the JMP Menu Editor, select File > Open.
Press Control and select Add New Submenu after.
Type Open My Data Tables and select JSL Commands.
Click Add Item.
6.
Select Open My Data Tables, delete Subitem placeholder in the Menu Label box, and then type Open Exercise Log.jmp.
7.
In the Run this JSL box, type Open("$SAMPLE_DATA/Napoleons March.jmp");.
8.
Click Save.
9.
Select the File menu to see the new menu item.
Delete one custom menu item by selecting the item and selecting Delete Selection from the options list.
Delete all custom menu items by selecting Revert All from the options list.
To delete items within a submenu, you must delete the entire submenu. Empty menus are not permitted. Select the submenu and select Delete Selection from the options list.
