JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Platforms
• Platforms That Support Multithreading
Some platforms in JMP are coded to take advantage of multiple CPUs on a machine, allowing these platforms to run significantly faster. This process is called multithreading.
The following platforms support multithreading:
Choice
Distribution
Factor Analysis
Fit Life by X
Fit Model: Parametric Survival, Mixed Model
, Generalized Regression
, and Response Screening
Life Distribution
Multivariate
Neural
Nominal Logistic
Nonlinear and Nonlinear Curve
Normal Mixtures in Cluster Analysis
Partial Least Squares
Partition
Predictor Screening Modeling Utility
Principal Components
Profiler (does not apply to Profilers launched from within other platforms)
Reliability Forecast
