Shows or hides individual detail reports for each variable in the analysis. See Individual Detail Reports for more information.
Shows or hides a goal plot for the data. The Goal Plot shows the spec-normalized mean shift on the x-axis and the spec-normalized standard deviation on the y-axis for each variable. See Goal Plot for more information.
Shows or hides a capability box plot for each variable in the analysis. The values for each column are centered by their target value and scaled by twice the minimum difference between the target value and the specification limits. See Capability Box Plots for more information.
Shows or hides a normalized box plot for the data. Each column is standardized by subtracting off the mean and dividing by the within standard deviation, and quantiles are formed for each standardized column. The box plots are formed for each column from these standardized columns. See Normalized Box Plots for more information.
Shows or hides a normalized box plot for the data. Each column is standardized by subtracting off the mean and dividing by the overall standard deviation, and quantiles are formed for each standardized column. The box plots are formed for each column from these standardized columns. See Normalized Box Plots for more information.
Shows or hides a summary report of capability indices calculated using the within sigma. See Summary Reports for more information.
Shows or hides a summary report of capability indices calculated using the overall sigma. See Summary Reports for more information.
Creates a summary table for the points plotted in the Goal Plot. This table includes the variable’s name, its spec-normalized mean shift, and its spec-normalized standard deviation. Each variable has two rows in this table: one for each sigma type (within and overall). See Make Goal Plot Summary Table for more information.
Reorders the box plots, summary reports, and individual detail reports. You can reorder by Initial Order, Reverse Initial Order, Within Sigma Cpk Ascending, Within Sigma Cpk Descending, Overall Sigma Ppk Ascending, or Overall Sigma Ppk Descending.
Saves the specification limits to a column property for each variable in the analysis. If no spec limit column property is present, the column property is created. If a spec limit column property is present, the values in the column property are overwritten. See Spec Limits Column Property for more information.
Saves the specification limits to a limits data table in tall format. See Limits Data Table for more information.
The Individual Detail Reports option displays a capability report for each variable in the analysis. Individual Detail Report shows the Individual Detail Report for PNP1 from the Semiconductor Capability.jmp sample data table as described in Example of the Process Capability Platform.
Show Spec Limits shows or hides vertical red lines on the histogram at the specification limits for the process.
Show Target shows or hides a vertical green line on the histogram at the process target.
Show Within Sigma Density shows or hides an approximating normal density function on the histogram with mean given by the sample mean and standard deviation given by the within estimate of sigma.
Show Overall Sigma Density shows or hides an approximating normal density function on the histogram with mean given by the sample mean and standard deviation given by the overall estimate of sigma.
Show Count Axis shows or hides an additional axis to the right of the histogram plot showing the count of observations.
Show Density Axis shows or hides an additional axis to the right of the histogram plot showing the proportion of observations.
Within Sigma Capability shows or hides capability indices (and confidence intervals) based on the within (short-term) sigma.
Within Sigma Z Benchmark shows or hides Z benchmark indices based on the within (short-term) sigma.
Overall Sigma Capability shows or hides capability indices (and confidence intervals) based on the overall (long-term) sigma.
Overall Sigma Z Benchmark shows or hides Z benchmark indices based on the overall (long-term) sigma.
The Within Sigma Normalized Box Plots and Overall Sigma Normalized Box Plots options show or hide box plots that have been normalized using the within sigma and overall sigma, respectively. When drawing Normalized Box Plots, JMP standardizes each column by subtracting off the mean and dividing by the standard deviation. The box plots are formed for each column using these standardized values.
Within Sigma Normalized Box Plot shows the Within Sigma Normalized Box Plot for a selection of the process variables in the Semiconductor Capability.jmp sample data table using wafer as a subgroup variable.
The Within Sigma Capability Summary Report and Overall Sigma Capability Summary Report options show or hide a table that contains the following statistics for each variable: LSL, Target, USL, Mean, Standard Deviation, Cpk, Cpl, Cpu, Cp, Cpm, and Nonconformance statistics. These statistics are calculated using the within sigma and overall sigma, respectively. Within Sigma and Overall Sigma Capability Summary Reports shows a subset of columns for both summary reports as described in Example of the Process Capability Platform. The following optional columns are available for this report:
To reveal these optional columns, right-click on the report and select the column names from the Columns submenu.
Note that the report (based on overall sigma) shows the overall capability indices Ppk, Ppl, Ppu, and Pp instead of the within capability indices Cpk, Cpl, Cpu, and Cp. The labeling of the overall capability indices depends on the setting of the AIAG (Ppk) Labeling preference.
The Make Goal Plot Summary Table option produces a summary data table that includes the variable’s name, its spec-normalized mean shift, and its spec-normalized standard deviation for further evaluation. Each variable has two rows in the summary table: one for each sigma type (within and overall). The points in the Goal Plot are linked to the rows in the Goal Plot Summary Table. If you apply row states to a point in the Goal Plot, you can change the corresponding row states in the Goal Plot Summary Table. Conversely, if you apply row states in the Goal Plot Summary Table, they are reflected on the Goal Plot.
Summary Table shows the Goal Plot Summary Table for the Semiconductor Capability.jmp sample data table as described in Example of the Process Capability Platform.
