Note: Process Capability analysis for individual responses is accessible through Analyze > Quality and Process > Control Chart Builder.
Capability indices in the Process Capability platform are computed using both the overall (long-term) variation and the within subgroup (short-term) variation. If the process is stable, these two measures of variation should yield similar results since the overall and within subgroup variation should be similar. You can specify subgroups in the launch window. The normalized box plots and summary tables can be calculated using either the overall or the within sigma variation. See Additional Examples of the Process Capability Platform for examples of capability indices computed for stable and unstable processes.
See Capability Indices for details about the calculation of the capability indices.
Note: The Process Capability platform expands significantly on the Capability analyses that are available through Analyze > Distribution and through Analyze > Quality and Process > Control Chart. By default, the Process Capability platform uses the appropriate AIAG notation for capability indices. It denotes an index constructed from an overall variation estimate using Ppk labeling. The previous Capability platform reported only overall variation with Cpk or Ppk labeling based on a platform preference. In the new platform, Cpk corresponds to within variation and Ppk corresponds to overall variation.
