Each system diagram in the Designs panel can include one or more profilers displayed in the Profiler panel. See Using JMP for details about manipulating the profiler graph (for example, configuring the X and the Y axes).
Select this option to display a dialog allowing you to enter specific values for current settings. See Profilers for details about setting the factor grid.
Select this option to configure the profiler’s settings. See Profilers for details about Factor Settings.
Select Show Remaining Life Distribution Profiler to show the Remaining Life Distribution profiler for the Reliability Block Diagram.
Enter a Survival Time to indicate the time after which the system’s probability for failure is greater than zero.
Tip: As an alternative to entering the Survival Time, select the small rectangle at the origin and drag it to the right to dynamically set the Survival Time.
Select Show Reliability Profiler to show the Reliability profiler for the Reliability Block Diagram.
Select Show Quantile Profiler to show the Quantile profiler for the Reliability Block Diagram.
Select Show Density Profiler to show the Density profiler for the Reliability Block Diagram.
Select Show Hazard Profiler to show the Hazard profiler for the Reliability Block Diagram.
Select Show Cumulative Hazard Profiler to show the Cumulative Hazard profiler for the Reliability Block Diagram.
Select Show BCI to show an overlay plot of the Birnbaum’s Component Importance measures for each component of the Reliability Block Diagram.
Select Show Remaining Life BCI to show an overlay plot of the Birnbaum’s Component Importance for Remaining Life.
Tip: As alternative to entering the Survival Time, click the small rectangle at the origin and drag it to the right to dynamically set the Survival Time.
Select Show Component Integrated Importance to show an overlay plot of the integrated importance measures for the components of the Reliability Block Diagram. The integrated importance measure for each component takes into account the failure rate of the component as well as the likelihood of failing instantaneously. See Si et al. (2012).
Select Show MTTF to view the Mean Time to Failure (MTTF) for the Reliability Block Diagram.
Select Show Component Distribution Functions to show an overlay plot of the distribution functions for the components of the Reliability Block Diagram.
Select Show Component Density Functions to show an overlay plot of the density functions for the components of the Reliability Block Diagram.
Select Show Component Hazard Functions to show an overlay plot of the hazard functions for the components of the Reliability Block Diagram.
Select Show Component Cumulative Hazard Functions to show an overlay plot of the cumulative hazard functions for the components of the Reliability Block Diagram.
