JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Reliability Block Diagram
Engineer
System Reliabilities
The Reliability Block Diagram platform displays the reliability relationship between a system's components and, if reliability distributions are given to the components, analytically obtains the reliability behavior. A Reliability Block Diagram (also known as a dependence diagram) illustrates how component reliability contributes to the success or failure of a system.
Example of a Reliability Block Diagram
Contents
Reliability Block Diagram Platform Overview
Example Using the Reliability Block Diagram Platform
Add Components
Align Shapes
Connect Shapes
Configure Components
The Reliability Block Diagram Window
Preview Window
Reliability Block Diagram Platform Options
Red Triangle Options for Designs and Library
Workspace Options
Distribution Properties for Components
Configuration Settings
Enter Nonparametric Distribution Data
Profilers Available for Reliability Block Diagrams
Profilers
Component Importance and Mean Time to Failure
Component Plots
Print Algebraic Reliability Formula
