To restructure a column or multiple columns, select Cols > Utilities and choose from the list of options. At least one column must be selected to enable these menu options.
Use the Text to Columns option to make a character column with delimited fields into multiple columns. Highlight a column from a data table and select Cols > Utilities > Text to Columns. The maximum number of delimited fields across all rows determines the number of new columns created.
Note: Text to Columns is case-sensitive.
The Text to Columns window has the following options:
Allows any empty rows to be counted as a category. An additional column named Missing is added to the data table. A value of 1 indicates an empty row.
Make a categorical column into multiple columns based on each distinct category. Highlight a column in a data table and select Cols > Utilities > Make Indicator Columns. Multiple columns with values of either 0 or 1 are created. A value of 1 indicates that the original column contains that specific category.
The Combine Columns option is the opposite of Text to Columns. Instead of making multiple columns, you can combine a set of columns into one character column with delimited fields.
Select Help > Sample Data Library and open Consumer Preferences.jmp.
Select the columns, Floss After Waking Up, Floss After Meal, and Floss Before Sleep.
Select Cols > Utilities > Combine Columns.
Select Selected Columns are Indicator Columns and click OK.
Combined Floss Column
The selected columns are represented in the Combined Floss column with each field separated by a comma. Only the columns that have a value of 1 are represented in the combined column for each given row.
A numeric column with non-integer values can also be compressed if there are fewer than 255 unique values. In this case, the List Check property is added to the column.
List Check Property Added to a Compressed Character Column
Column Info Window Showing Numeric Column before and after Compression
To compress columns, select one or more columns and select Cols > Utilities > Compress Selected Columns. (Select all columns if you do not know which columns can be compressed.)
You can distribute your data into equal width bins using the Make Binning Formula option. Select the column or columns that you want to divide into bins, and select Cols > Utilities > Make Binning Formula. New formula columns are added to the data table.
Select Use Value Labels to show a label instead of the value.
Select Use Range Values to include the lower and upper values for each range in the label.
Select No Labels to use the lower edge value as the label.
Select Help > Sample Data Library and open Big Class.jmp.
Select the height column.
Select Cols > Utilities > Make Binning Formula.
Change the offset to -0.5.
Keep the width set to 5.
6.
For the labels, keep it set to Use Value Labels, so that you can see the range of values for the bin.
Completed Binning Window
7.
Click Make Formula Columns.
A column called height Binned is added to the Big Class.jmp data table.
8.
To see how the formula is calculated, right-click on the height Binned column and select Formula.
Formula
To perform further analyses on your data, use the New Formula Column menu options from your existing data table. Formula columns use formulas or calculations to define column values.
Right‐click a column heading in your data table and select New Formula Column. Choose from either Transform, Combine, Aggregate, Distributional, Date, Row, or Formula to calculate column values. A new formula column is added to the data table. See Virtual Columns for a description of these options.
Note: The same options exist in both the New Formula Column menu, and the right-click column menu in the launch window. However, performing these tasks in a launch window results in a temporary column, and New Formula Column adds a new column to the original data table.
Example of Virtual Column Menu
Select a function from the Transform menu to create a virtual column containing the calculations based on the selected function. For details about listed functions, see the JSL Syntax Reference. Also refer to Fitting Linear Models for additional information.
Select multiple columns to access the Combine menu. The Combine menu creates a virtual column containing the calculations based on the selected function. For details about listed functions, see the JSL Syntax Reference.
Select a function from the Aggregate menu to create a virtual column containing the statistics calculated from the selected column (or part of a column if you specified a Group By column). For details about listed functions, see the JSL Syntax Reference.
Note: The Group By option is useful for these functions.
Select a function from the Distributional menu to create a virtual column containing the statistics calculated from the selected column.
Creates two columns. The Informative column replaces missing values with the column mean. The Is Missing column indicates 1 for missing values, and 0 otherwise.
For column values containing date or time values, select a function from the Date Time menu to create a virtual column containing values calculated from the selected column. For details about listed functions, see the JSL Syntax Reference.
Select a function from the Character menu to create a virtual column containing strings formed by the selected Character function. For details about listed functions, see the JSL Syntax Reference.
Select a function from the Row menu to create a virtual column containing calculations determined by the selected Row function. For details about listed functions, see the JSL Syntax Reference.
See the Scripting Guide book for details about Row functions.
Select Help > Sample Data Library and open Companies.jmp.
Select the Type column by clicking once on the column heading.
Select Cols > Utilities > Recode.
In the Recode window, enter the desired values in the New Value boxes. For this example, enter Technical in the Computer row, and Drug in the Pharmaceutical row.
Click Done and select the In Place option from the menu.
Recode Window
Note: If you enter a non-numeric value in a column with a Numeric data type, you are prompted to convert the data type to Character. Click Yes to convert the column and display the new value. Click No to keep the column Numeric and display a missing value.
When you are finished recoding data, click Done to view the following options:
becomes active when multiple values are selected. Click Group to make highlighted values part of the same group. If you previously edited a value before grouping, the edited value becomes the group representative in the New Value column. Otherwise, the group representative is the value that occurs most often.
right-click selected values to select a different grouping value, or group representative. The Group To command displays the Old Values that occur most often in the data table with their corresponding New Values (if they are different). The list displays the first 8 possible group representatives.
when two values are highlighted, select Swap New Values to make the new value of the first value adopt the new value of the second value, and vice versa.
right-click a single value from a group and select Make Representative to make the selected value the New Value.
Select the following Group Similar Values commands to increase the accuracy of grouping:
Select Help > Sample Data Library and open Candy Bars.jmp.
Select the Name column.
Select the Max Character Difference option and type “6”.
6.
Grouped by Character Difference
7.
Right-click Almond Roca and select Make Representative to change the new value to represent a different value within the group.
Make Representative
8.
Click Done > In Place to replace the original data with the recoded data in the table.
Select the Difference Ratio option and type “.5”.
6.
Grouped by Difference Ratio
7.
From the red triangle menu, select Done > New Column to save the recoded data in a new column in the data table.
