If you want to run the same script every time you start JMP, name it jmpStart.jsl and place it in one of the following folders, as appropriate for your operating system. When JMP starts, JMP looks for the jmpStart.jsl script in these folders in the order in which they are listed here. The first one that is found is run, and the search immediately stops.
Note: Some path names in this section refer to the “JMP” folder. On Windows, in JMP Pro, the “JMP” folder is named “JMPPro”. In JMP Shrinkwrap, the “JMP” folder is named “JMPSW”.
C:\Users\<username>\AppData\Roaming\SAS\JMP\<version number>
The jmpStart.jsl script runs only for a particular user on a computer. You can add a script named jmpStartAdmin.jsl in one of the following places, as appropriate for your operating system. This script is run for every user on a computer. JMP searches for the administrator start-up script first, and runs it if found. Then JMP searches for the user start-up script, and runs it if found.
