Note: Database table names that contain the characters $# -+/%()&|;? are not supported.
Converts an expression to code that you can use in an SQL Select statement. Use Expr(...) for literal expressions. Use NameExpr(name) for expressions stored in a variable. Otherwise, the expression returns the expression to convert.
Null (or the data table object, if OnRunComplete is included).
You can include a .jmpquery file in a script and run the query in the background using the <<Run Background message.
