JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
• Save and Share Data
Save and Share Data
Get Your Data Out of JMP
This chapter covers the following topics:
Save data tables as text files, SAS data sets, Excel files, and so on
Save reports as interactive HTML 5 or Adobe Flash files
E-mail reports and data tables
Save analyses as scripts
Create JMP journals or projects
Save log windows
The method that you choose depends on how you want to interact with your analyses in the future:
If you want to interactively present your data, you might choose to create a JMP journal.
If you want to send data tables, linked reports, and other items to someone, you might choose to create a JMP project.
If you want to continue to explore a report later, you might choose to create a JMP report.
Contents
Save and Share Data Tables
Save as a Microsoft Excel File
Save as a CSV File
Save as a Text File
Save as a SAS Transport File
Save as a SAS Data Set
Save Data Tables to a Database
Replace a Database with a Data Table
E-mail a Data Table
Save and Share Reports
E-mail a Report
Save the Report as Interactive HTML
Save as PowerPoint
Save as Flash
Setting the Graphic DPI
Save Your Analysis as a Script
Print Reports
Copy and Paste Reports
JMP Journals
Save JMP Sessions
JMP Projects (Windows Only)
Save a Log Window
