JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Scripting Guide
• Scripting Graphs
Scripting Graphs
Create and Edit 2-Dimensional Plots
You can run a script inside a graph, which draws inside the graph. You can do this with almost any graph from an analysis platform, or you can create your own new graphs. In both cases, you are storing a JSL script inside a graph, and the script runs each time you display the graph.
For scripting 3-dimensional plots, see the chapter
Three-Dimensional Scenes
Contents
Adding Scripts to Graphs
Ordering Graphics Elements Using JSL
Adding a Legend to a Graph
Creating New Graphs From Scratch
Making Changes to Graphs
Graphing Elements
Plotting Functions
Getting the Properties of a Graphics Frame
Adding a Legend
Drawing Lines, Arrows, Points, and Shapes
Lines
Arrows
Markers
Pies and Arcs
Regular Shapes: Circles, Rectangles, and Ovals
Irregular Shapes: Polygons and Contours
Adding text
Colors
Transparency
Fill patterns
Line types
Drawing With Pixels
Interactive graphs
Handle
MouseTrap
Drag Functions
Troubleshooting
Creating Background Maps
