Open the Popcorn.jmp sample data table.
Select Tables > Sort.
The Sort Window
Click By to add the columns to the sort list.
6.
Type a name for the new sorted table in the box beside Output table name. For this example, type sorted popcorn.
Completed Sort Window
7.
Sorted in Ascending and Descending Order
To replace the original data table with the sorted table instead of creating a new table with the sorted values, click the box beside Replace Table. This option is not available if there are any open report windows generated from the original table.
To keep this window open after clicking OK, check the box beside Keep dialog open.
