The Tables > Summary command calculates various summary statistics, including the mean and median, standard deviation, minimum and maximum value, and so on.
In addition to one column for each grouping variable, the table contains frequency counts in a column named N Rows with counts for each grouping level.
A summary table is not saved when you close it unless you select File > Save As to give it a name and location.
Select Tables > Summary.
Note: For details about the options in the red triangle menu, see Columns Filter Menu in JMP Platforms.
Name the summary table by typing a name in the box beside Output table name.
6.
Click OK.
Click the Statistics button.
Select one of the standard univariate descriptive statistics from the Statistics drop-down menu. The statistics are described in Explanation of Statistics.
If you want the statistics summarized by group, highlight the column(s) that you want to be your grouping variables and click Group to move the variable into the grouping variables list. See Example of Creating a Summary Table, for an example. If you add only grouping variables, the summary table shows a count for each group.
You can also change the order of the grouping variables using the Value Ordering column property. See Value Ordering in The Column Info Window.
To add marginal statistics (for the grouping variables) to the output columns, click the box beside Include marginal statistics. In addition to adding marginal statistics for each grouping variable, JMP adds rows at the end of the table that summarize each level of the first grouping variable. For example, proceed as follows:
Open the Companies.jmp sample data table.
Select Mean.
Select Include marginal statistics.
7.
In the box under For quantile statistics, enter value (%) type the desired quantile value (%) for the first quantile (for example, 25).
Select the applicable column and click Statistics.
Select Quantiles.
To change the format of the statistics column name in the summary table, select from one of the formats in the statistics column name format menu. Statistics Column Name Format Options and Examples illustrates the available options. Assume that you are creating a summary table of the mean profits for a company. Your original column name is Profits ($M).
You can select whether to link the summary table to the original data table. By default, the Link to original data table option is selected. If you want to edit the data in the summary table, deselect the Link to original data table option. When the summary table is linked to the original data table, you cannot edit the data in the summary table, since that would modify and compromise the original data.
If you select the Keep dialog open option, the Summary window remains open after you click Create. Notice that once you select this option, the OK button is replaced by a Create button.
Click Subgroup to move the variable(s) into the subgroup list.
In the Statistics list, select the specific statistic that you want.
Click OK.
Click OK.
From the red triangle menu in the upper left corner of the data table grid, select Add Statistics Column.
6.
Select the column that you want, click Statistics, and select the specific statistic that you want. For this example, select profit/emp and click Statistics, and then select Mean.
7.
Click OK.
