Variables Controls
When there are more than two independent variables, you can select which two are displayed on the x- and y-axes using the radio buttons in this panel. The sliders and text boxes set the current values of each variable, which is most important for the variables that are not displayed on the axes. In essence, the plot shows the three-dimensional slice of the surface at the value shown in the text box. Move the slider to see different slices.
Lock Z Scale locks the z-axis to its current values. This is useful when moving the sliders that are not on an axis.
Activated X and Y Grids
Dependent Variable Controls
Enables you to show or hide the top or bottom of a surface. If Above only or Below only is selected, the opposite side of the surface is darkened.
Most of the controls for Isosurface are identical to those of Sheet, points. Dependent Variable Controls for Isosurfaces shows the default controls, illustrating the slightly different presentation.
