Item characteristic curves for each question appear in the top section of the output. Initially, all curves are shown stacked in a single column. They can be rearranged using the Number of Plots Across command, found in the drop down menu of the report title bar. For Component Curves, four plots across are displayed.
Questions provide varying levels of information for different ability levels. The gray information curves for each item show the amount of information that each question contributes to the total information of the test. The total information of the test for the entire range of abilities is shown in the Information Plot section of the report (Information Plot).
JMP shows this correspondence with a dual plot. The dual plot for this example is shown in Dual Plot.
This example shows a wide range of abilities. Q10 is rated as difficult, with an examinee needing to be around half a standard deviation above the mean in order to have a 50% chance of correctly answering the question. Other questions are distributed at lower ability levels, with Q11 and Q4 appearing as easier. There are some questions that are off the displayed scale (Q7 and Q14).
Is the b parameter from the model. A histogram of the difficulty parameters is shown beside the difficulty estimates.
Is the a parameter from the model, shown only for 2PL and 3PL models. A histogram of the discrimination parameters is shown beside the discrimination estimates.
Is the c parameter from the model, shown only for 3PL models.
