JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Multivariate Response Models
• The Manova Fit Options
Description of the Manova Fit Options
describes the options in the red triangle menu next to Manova Fit.
Save Discrim
Performs a discriminant analysis and saves the results to the data table. For more details, see
Discriminant Analysis
Save Predicted
Saves the predicted responses to the data table.
Save Residuals
Saves the residuals to the data table.
Model Dialog
Shows the completed launch window for the current analysis.
Script
Contains options that are available to all platforms. See
Using JMP
