A simplex centroid design of degree k with n factors consists of mixture runs with the following characteristics:
and so on, up to k factors at a time combined at k equal levels.
Select DOE > Mixture Design.
Enter the number of ingredients in the box under K. JMP creates runs for each ingredient without mixing. JMP also creates runs that mix equal proportions of K ingredients at a time to the specified limit.
Click the Simplex Centroid button.
Example of Factor Settings and Output Options
7.
Specify Run Order, which is the order in which the runs that appear in the data table that you will create. Run order choices are:
Keep the Same: The rows (runs) in the output table appear as they do in the Factor Settings panel.
Sort Left to Right: The rows (runs) in the output table appear sorted from left to right.
Randomize: The rows (runs) in the output table appear in a random order.
Sort Right to Left: The rows (runs) in the output table appear sorted from right to left.
Randomize within Blocks: The rows (runs) in the output table appear in random order within the blocks that you set up.
8.
Specify Number of Replicates. The number of replicates is the number of times to replicate the entire design, including center points. Enter the number of times you want to replicate the design in the associated text box. One replicate doubles the number of runs.
9.
Click Make Table.
The table of runs for a design of degree 1 with three factors (left in Three-Factor Simplex Centroid Designs of Degrees 1 and 2) shows runs for each single ingredient followed by the center point. The table of runs to the right is for three factors of degree 2. The first three runs are for each single ingredient, the second set shows each combination of two ingredients in equal parts, and the last run is the center point.
Choose DOE > Mixture Design.
Click Continue.
Enter 1 in the K box, and click Simplex Centroid to see the design on the left in Create Simplex Centroid Designs of Degrees 1 and 2.
Click the Back button, click Continue, and then enter 2 in the K box. Then click Simplex Centroid to see the design on the right in Create Simplex Centroid Designs of Degrees 1 and 2.
Click Simplex Centroid.
Click Make Table.
Partial Listing of Factor Settings for Five-Factor Simplex Centroid Design shows part of the 31-run design. Note that your table might look different because the design was created with Run Order set to Randomize.
