JMP uses the modeling type to determine a column’s role. Continuous columns are assumed to be analysis columns. See Analysis Columns. Ordinal or nominal columns are assumed to be grouping columns. See Grouping Columns.
You can always change the default action by right-clicking on a column and selecting Combine Tables or Separate Tables. For more details, see Right-Click Menu for Columns.
Tabulate does not include observations with a missing value for one or more grouping columns by default. You can include them by checking the Include missing for grouping columns option.
To specify codes or values that should be treated as missing, use the Missing Value Codes column property. You can include these by checking the Include missing for grouping columns option. For more details about Missing Value Codes, see the Using JMP book.
In Tabulate, a table is defined by its column headings and row labels. These sub-tables are referred to as row tables and column tables. See Row and Column Tables.
Select Analyze > Tabulate.
Drag size into the Drop zone for rows.
7.
8.
Drag type to the far right of the table.
9.
Drag sex under the table.
Grouping columns display the column name on top of the categories associated with that column. For some columns, the column name might seem redundant. Remove the column name from the column table by right-clicking on the column name and selecting Remove Column Label. To re-insert the column label, right-click on one of its associated categories and select Restore Column Label.
You can edit a statistical key word or a statistical label. For example, instead of Mean, you might want to use the word Average. Right-click on the word that you want to edit and select Change Item Label. In the box that appears, type the new label. Alternatively, you can type directly into the edit box.
