Select DOE > Space Filling Design.
Click Continue.
Click the Uniform button. JMP creates this design and displays the design runs and the design diagnostics as shown in Factor Settings and Diagnostics for Uniform Space-Filling Designs with Eight Runs.
Note: The emphasis of the Uniform design method is not to spread out the points. The minimum distances in Factor Settings and Diagnostics for Uniform Space-Filling Designs with Eight Runs vary substantially.
7.
Click Make Table.
A Uniform design does not guarantee even spacing of the factor levels. However, increasing the number of runs and running a distribution on each factor (use Analyze > Distribution) shows flat histograms.
