Click OK.
Histogram Options > Show Counts
Confidence Interval > 0.95
Outlier Box Plot, to remove the outlier box plot
To save this analysis, select Script > Save Script to Data Table from the red triangle menu for Distributions. The Distribution script appears in the Table panel.
To re-create the analysis, select Run Script from the red triangle menu for the Distribution script.
