CASE STUDY: JMP066
Chemical Process Improvement in Resin Production (Part 1)
by Frank Deruyck, HOGENT University
Volker Kraft, JMP
Key Concepts: Process capability, process modeling, Design Space Profiler
Laboratory glassware.
Dr. Frank Deruyck
University College Ghent
Dr. Volker Kraft
JMP
Objective
Assess process stability and capability to establish a baseline understanding of quality performance, before developing a process model to identify and control critical parameters for quality improvement.
Background
BLX Chemicals is a leading producer of high-quality resin that serves as essential building blocks across numerous industries. From advanced manufacturing and coatings to adhesives, composites, and innovative material solutions, resins help customers create products that are stronger, more durable, and more sustainable.
A critical quality attribute (CQA) of a resin is purity, which describes how free it is from contaminants or any unreacted components. High purity ensures consistent performance, stability, and reliability in applications such as coatings, adhesives, and polymer production. Even small impurities can influence color, strength, or reactivity, making careful purification and quality control essential.
In recent months, the resin manufacturing process operated at the best achievable stability, which was still not optimal. As a result, purity did not meet its specification for too many batches, which led to a poor baseline capability of the process. The chemical engineering team wants to address this issue.
To ensure acceptable product quality, an additional purification step is required. This initial purification step is applied before the final purification takes place, which leads to an increased processing time. It is further required to measure purity on each product. Since sufficient data for online monitoring of purity are not available, an offline measurement of purity became necessary, adding even more time to the overall process.
The resin production runs 22.5 hours per day over two shifts and uses two reactors.
The Task
