Multivariate Statistical Methods
What are multivariate statistical methods?
Many studies collect multiple measurements on the same individual, sample, product, or process. For example, a pharmaceutical tablet might be characterized by hardness, dissolution rate, weight, and moisture content. A customer survey might collect ratings for various features of a product. Because these variables are often related, analyzing them one at a time can miss important patterns.
Multivariate statistical methods analyze multiple variables simultaneously. By considering relationships among variables, these methods can reveal structure that is difficult or impossible to see in separate univariate analyses.
Multivariate methods are commonly used to:
  • Explore relationships among variables.
  • Identify patterns in complex data sets.
  • Reduce many variables to a smaller set of underlying dimensions.
  • Group similar observations.
  • Classify observations into known categories.
  • Model and predict multiple responses simultaneously.
A major benefit of multivariate analysis is dimension reduction, the ability to summarize information from many variables with only a few components, factors, or latent variables while preserving the most important features of the data.
Types of multivariate methods
Multivariate methods are often grouped into two broad categories: unsupervised learning and supervised learning.
Unsupervised learning
Unsupervised methods are used when the goal is to understand the structure of a data set without specifying a response variable. For the multivariate component, all variables are treated as response variables. The analysis focuses on discovering patterns, relationships, and groups within the data.
Common objectives include:
Methods such as principal component analysis, factor analysis, and cluster analysis are common unsupervised learning techniques used for exploration and description.
Supervised learning
Supervised methods are used when one or more variables are designated as responses and the remaining variables are used as predictors. The goal is to build a model that explains, predicts, or classifies outcomes.
Many supervised learning methods are specifically used with multiple response variables. Other supervised learning methods (for example, principal component regression) treat the predictor variables as a multivariate problem, then use the results in a univariate model.
Methods such as partial least squares regression, principal component regression, discriminant analysis, and multivariate multiple regression are common supervised learning techniques used for prediction and classification.
Summary of common multivariate methods
Method Category Typical use
Principal component analysis (PCA) Unsupervised Reduce dimensionality and visualize multivariate relationships.
Exploratory (common) factor analysis Unsupervised Identify latent factors that explain observed variables.
Cluster analysis Unsupervised Group observations into clusters.
Principal component regression (PCR) Supervised Build regression models when predictors are highly correlated.
Partial least squares (PLS) regression Supervised Predict one or more responses using many correlated predictors.
Discriminant analysis Supervised Classify observations into known groups.
Confirmatory factor analysis Supervised Test a hypothesized factor analysis model.
Structural equation modeling (SEM) Supervised Use as a general framework for many modeling techniques.
MANOVA Supervised Model several response variables simultaneously using a single grouping variable.
Multivariate multiple regression Supervised Model several response variables simultaneously using multiple predictor variables.
Choosing a method
The appropriate multivariate method depends on the objective of the analysis.
By leveraging relationships among variables, multivariate methods provide a powerful framework for exploring, understanding, and modeling complex data. They are widely used in science, engineering, manufacturing, healthcare, marketing, and many other fields where important insights emerge only when variables are considered together rather than one at a time.
