Data Mining and Predictive Modeling
Classification Trees (Partition)
Predict a categorical response as a function of predictor variables using recursive partitioning.
JMP features demonstrated:
Analyze > Modeling > Partition
Regression Trees (Partition)
Predict a continuous response as a function of predictor variables using recursive partitioning.
Naive Bayes
Predict a categorical response as a function of predictor variables using Bayes conditional probabilities.
Analyze > Modeling > Naive Bayes
K Nearest Neighbors
Predict a categorical or continuous response as a function of predictor variables using the outcomes of similar observations.
Analyze > Modeling > K Nearest Neighbors
Neural Networks
Model complex relationships between inputs and outputs using flexible neural network models.
Analyze > Modeling > Neural
Support Vector Machines
Modeling technique to predict (classify) binary and multi-class outcomes as a function of continous and/or categorial predictor variables
Analyze > Predictive Modeling > Support Vector Machines
Creating a Validation Column (Holdout Sample)
This page describes how to create a validation column in JMP®. Validation, or out-of-sample cross-validation, is used to assess the predictive ability of a model.
New Column, Initialize Data, Random Indicator, Value Labels
Text Explorer - Describing Unstructured Text Data
This page describes how to use the text explorer platform to describe the counts and frequencies of words and phrases in unstructured data.
Term and phrase lists and word clouds.
Text Explorer - Analyzing Unstructured Text Data
This page describes how to use the text explorer platform to analyze unstructured text data in JMP and JMP Pro.
Latent class analysis, latent semantic analysis, SVD scatterplots, and saving results.
Association Analysis (Market Basket Analysis)
Develop rules that indicate the likely occurrence of items based on the occurrence of other items to identify items that often appear together or identify dependent or associated events.
How to use association platform, which displays frequent item sets and rules by default.  Help with interpreting the output is provided.
Model Comparison and Selection
Use the Model Comparison platform to compare competing statistical models and select the best performing model.
Analyze > Predictive Modeling > Model Comparison (also applies to the Model Comparison performed within the Formula Depot)
Back to Top
