Step-by-Step Guide
Basic Expression Analysis and Normalization with JMP® Genomics 6.0
This document shows you how to perform a basic analysis and normalization of your expression data set. In this example, we examine the GEO data set GSE11352 and track gene expression changes in response to estrogen treatment of MCF7 cells during a time-course experiment using Affymetrix arrays. You will learn how to set up the Basic Expression Workflow and interpret the results, become familiar with different options for normalizing array data, and review additional capabilities for downstream analysis of workflow results.
  Per favore iscrivetemi a JMP Newswire, la newsletter mensile per gli utenti JMP.
  Sì, potete inviarmi email occasionalmente su prodotti e servizi JMP.
JMP è una divisione di SAS Institute Inc. e le informazioni dell'utente verranno gestite in conformità con l'Informativa sulla privacy SAS.
JMP white paper on a tablet
Back to Top
