Step-by-Step Guide
Getting Started with JMP® Clinical 3.1
This step-by-step guide will introduce you to JMP Clinical 3.1 software. You will be guided through running a basic safety workflow using a sample data set from a study of the treatment of subarachnoid hemorrhages with the drug Nicardipine. You will then review the results of the workflow, which include summaries of patient demographics, interventions, events and findings, using the Data Filter and interactive graphics to select subsets of interesting patients for further exploration. Generating patient profiles and safety narratives will also be demonstrated.
  Per favore iscrivetemi a JMP Newswire, la newsletter mensile per gli utenti JMP.
  Sì, potete inviarmi email occasionalmente su prodotti e servizi JMP.
JMP è una divisione di SAS Institute Inc. e le informazioni dell'utente verranno gestite in conformità con l'Informativa sulla privacy SAS.
JMP white paper on a tablet
Back to Top
