Treatment Group Difference Cutoff
Use the field or slider to specify a cutoff for the treatment group differences (calculated from the treatment group LSMeans) that are displayed in the X axis of Volcano Plots formed for the statistical tests.
This cutoff is used in order to further select significantly interesting hypothesis tests.
Note: Values entered in using this parameter should be positive values indicating the magnitude of the cutoff. You can specify direction using the Direction of the Treatment Group Difference parameter.
To Specify a Treatment Group Difference Cutoff:
| 8 | Make sure the Add treatment group difference threshold to select significant tests box is checked. |
| 8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
