Adverse Events Narratives
This chapter
Data Sets Generated by the Adverse Events Narrative Report
A number of different SAS data sets are generated by the Adverse Events Narrative. These data sets and the variables that they contain are detailed in the tables below:
Variables in the narrtext_XXX.sas7bdat data set are as follows:.
Variable |
Contents |
USUBJID |
Unique Subject Identifier |
SITEID |
Study Site Identifier |
ARM |
Description of Planned Arm |
ACTARM |
Description of Actual Arm (if available) |
INVHEAD |
Either Investigator Name (precedence), Investigator Identifier, or Study Site Identifier depending on variable available (INVNAM, INVID or SITEID, respectively) |
RACETXT |
Formatted version of RACE |
AESTDAYTXT |
Formatted version of the start day for the adverse event |
AEENDAYTXT |
Formatted version of the end day for the adverse event |
DSSTDAYTXT |
Formatted version of the completion or discontinuation day from (DSSTDTC, if DS available) |
EXSTDAYTXT |
Formatted version of study day of minimum Start Date/Time of Treatment (EXSTDTC, if EX available) |
AESEVTXT |
Formatted version of the event severity. Either from Standard Toxicity Grade (AETOXGR, precedence) or Severity/Intensity (AESEV) (if available) |
AERELTXT |
Formatted version of the event causality (AEREL, if available)
AEACNTXT |
Formatted version of action taken with study treatment (AEACN, if available)
EXSTDY_MINTXT |
Formatted version of minimum Start Date/Time of Treatment (EXSTDTC, if EX available) |
SAETEXT |
Formatted list of reasons for SAE status from Involves Cancer (AESCAN), Congenital Anomaly or Birth Defect (AESCONG), Persist or Sign if Disability/Incapacity (AESDISAB), Results in Death (AESDTH), Requires or Prolongs Hospitalization (AESHOSP) Is Life Threatening (AESLIFE), Occurred with Overdose (AESOD), Other Medically Important Serious Event (AESMIE) |
AGE |
Age |
AGEU |
Formatted version of AGEU or "year" if AGEU not available |
SEX |
Sex |
RFSTDTC |
Subject Reference Start Date/Time. Used to calculate study days if study days not available |
AESEQ |
Unique number within subject defined from AESEQ or created by JMP Clinical |
AESTDTCP |
Formatted Start Date/Time of Adverse Event. Asterisk (*) present if partial date for AESTDTC |
AEENDTCP |
Formatted End Date/Time of Adverse Event. Asterisk (*) present if partial date for AEENDTC |
AETERM |
Asterisk (*) present if partial date available for RFSTDTC, which means all study days are questionable unless individual study days provided in domain data sets. |
NEARAETEXT |
Formatted list of adverse events occurring within the specified by the dialog (default = 3). Contains severities based on AETOXGR or AESEV, if available. Contains only unique instances of event/severity within the . Asterisks (*) imply a partial start date for the particular event. |
FLAG |
Values are "No Treatment", "On Treatment" (on or after first dose and on or before last dose of any study drug), "Pre Treatment" (before any study drug) or "Post Treatment" (after any study drug) |
FLAGTXT |
The text of FLAG, with asterisk if any partial dates in EX. All dates/study days involving treatment should be reviewed. INEXDOSEIMP = 1 in these cases. |
DRUGATFIRSTDOSE |
Formatted text of all drugs from EX that are taken on the first date of any study drug (EXTRT, EXDOS, and EXDOSU). |
AEDAYSFROMFIRSTDOSE |
Number of days from first dose of any study drug (only if EX available) |
AEDAYSFROMLASTDOSE |
Number of days from last dose of any study drug (only if EX available) |
DRUGATEVENT |
Formatted text of all drugs from EX that are taken on the day on which the event occurs (EXTRT, EXDOS, and EXDOSU). Available only if all study treatments are taken at least once per day (from dialog). |
NUMDAYSDRUGATTIME |
List for the number of days the patient has been on each drug from DRUGATEVENT. |
CMTEXT |
Formatted list of concomitant medications that patient is on when the event starts. Can include indication (CMINDC) if requested from dialog. Contains only unique instances of medication/indication. Asterisks imply a partial or missing start or end date for the particular medication. (only if CM available) |
MHTEXT |
Formatted list of medical history with year from MHSTDTC (if MH available) |
DSSTDTCP |
Formatted Start Date/Time of Disposition Event for completion/ discontinuation. Asterisk present if partial date for AESTDTC. |
TOTALCMCNT |
Total concomitant records available for subject |
HOTEXT |
Formatted list of health-care encounters if all are requested from dialog. Asterisks imply a partial start or end date. (only if HO available) |
NEARHOTEXT |
Formatted list of health-care encounters occurring within the specified by the dialog (default = 3). Asterisks imply a partial start date. (only if HO available). |
PREDATATXT_A |
Formatted version of the day/date with findings A prior to event. Made of PREDT_A and PRESTDY_A. Results apply to Findings B and Findings C with equivalent variables. |
POSTDATATXT_A |
Formatted version of the day/date with findings A subsequent to event. Made of POSTDT_A and POSTSTDY_A. Results apply to Findings B and Findings C with equivalent variables. |
BASETEXTA |
String of baseline findings, limited to abnormal lab tests. Results apply to Findings B and Findings C with equivalent variables. |
PRETEXTA |
String of findings just prior to event, limited to abnormal lab tests with a normal baseline or those different from baseline. Results apply to Findings B and Findings C with equivalent variables. |
POSTTEXTA |
String of findings just subsequent to event, limited to abnormal lab tests with a normal baseline or those different from baseline. Results apply to Findings B and Findings C with equivalent variables. |
Variables in the narrmeta_XXX.sas7bdat data set are as follows:.
Variable |
Contents |
CM |
Y if CM domain available (with requirements met), N if not. |
DS |
Y if DS domain available (with requirements met), N if not. |
EX |
Y if EX domain available (with requirements met), N if not. |
MH |
Y if MH domain available (with requirements met), N if not. |
HO |
Y if HO domain available (with requirements met), N if not. |
EXDaily |
Y or N according to selected option in dialog as to whether all drugs are taken daily. If EX not available, this is missing. |
HO |
The HO value is nonmissing if nearby hospitalizations are requested from the dialog, and the value is based on user-selection (default = 3). This value is missing if all hospitalizations are reported or if the HO domain is not available. |
AECONTRT |
Y or N depending on whether variable is available. |
AEOUT |
AEREL |
AESER |
CMINDC |
ACTARM |
AE |
Based on dialog preference, default of 3 days. |
Variables for Findings A1 () |
NumEvents |
Number of summarized events (rows of narrtext_XXX.sas7bdat). Each row is a separate narrative. |
Note: Completion-Discontinuation status is selected from the records where DSCAT = Disposition Event and EPOCH = Treatment (if either or available). If multiple records are available from this subsetting, the last is chosen. Completers are those with COMPLETE in DSDECOD.
