Group Level
Use this option to specify the level for grouping preferred terms or verbatim terms.
Possible group levels are listed in the following table:
Group Level1
Corresponding Variable
Function
Body System
AEBODSYS in AE
• Uses a dictionary-derived text description of the affected body system, listed in the AEBODSYS column in AE.
Higher Level Term (HLT)
AEHLT in AE
• A superordinate descriptor for multiple preferred terms (PTs).
Higher Level Group Term (HLGT)
AEHLGT in AE
• A superordinate descriptor for multiple higher level terms (HLTs)
Standard MedDRA Query
• Grouping of MedDRA terms, at a defined level, that describes a specific medical condition.
Primary System Organ Class (SOC)
AESOC in AE
• Uses Primary System Organ Class level of adverse events as categories.
Lowest Level Term (LLT)
AELLT in AE
• Uses Lowest Level Term level of adverse events as categories.
Body System or Organ Class
AEBODSYS in AE
• Uses body system or Organ Class level of adverse events as categories.
Dictionary-Derived Term
AEDECOD in AE
• Uses Dictionary-Derived Term level of adverse events as categories.
Reported Term for the Adverse Event
AETERM in AE
• Uses Reported Term for the Adverse Event level of adverse events as categories.
Category
CMCAT in CM, or SUCAT in SU
• Uses Category level of interventions as categories.
Category for Medication
Note: The dictionary name and version used to generate the descriptions should be included as part of the submission.
Note: In some reports, options are dynamically populated by available terms (with the list available filtered based only on hierarchically sensible grouping choices).
To Specify the Group Level:
8 Select the group level corresponding to the adverse event or intervention terms that you want to use from the drop-down menu.
