JMP Clinical Review API
The JMP Clinical Review API provides functions for manipulation of JMP Clinical Reviews and Reports.
The general usage centers around a reference to a Review Builder based on a generated ID. The ID may be obtained via one of several functions below, or will be made available in the context of Review Builder executing code embedded within a JMP data table within a Report. The variable JMPClinicalReviewID will be the ID of the Review in which the code is executing. In this way, the script writer may customize output generated by a JMP Clinical Report by simply adding a script to the data table within the Report.
Descriptions of each function is provided below. Additionally, the installed API/example folder contains example scripts which demonstrate the usage of the functions.
Functions:
JMPClinicalReviewAPI:getCurrentStudy
Returns the name of the current study.
Returns:
If there is a current study, the study name (a string); otherwise Empty().
Syntax
JMPClinicalReviewAPI:getCurrentStudy = function({}, {},
expr(StudyListClass:studyListSingleton):getCurrentStudy();
JMPClinicalReviewAPI:setCurrentStudy
Sets the current study to the one specified.
Arguments:
study
{study} - where "study" is a string containing the name of the study to set as the current study
{Empty()} - to set the current study to <None>
Returns:
1- if the current study was successfully set
0 - if no study was successfully set
Syntax:
JMPClinicalReviewAPI:setCurrentStudy = function({study}, {cs},
JMPClinicalReviewAPI:getReviewBuilder
This function gets an instance of a Review Builder. If an instance doesn't exist, one will be created.
Arguments:
show
{show=1} - shows the window
{show=0} - hides the window
Returns:
A reference to the Review Builder object.
Syntax:
JMPClinicalReviewAPI:getReviewBuilder = function({show=1}, {default local},
JMPClinicalReviewAPI:closeReviewBuilder
This function closes the current Review Builder instance.
Arguments:
None
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:closeReviewBuilder = function({}, {default local},
JMPClinicalReviewAPI:openReviewTemplate
This function opens a Review Template.
Arguments:
templatePath - path to the Review Template to open
Returns:
Syntax:
JMPClinicalReviewAPI:openReviewTemplate = function({templatePath}, {default local},
JMPClinicalReviewAPI:createStaticReport
Creates a static version (PDF, RTF, PowerPoint) of the review.
Arguments:
type - "PDF", "RTF", or "PowerPoint"
includeNotes - 0 = do not include notes, 1 = include notes
filePath - full file path where to save report. If not specified, the default static report location is used - as specified in the configuration as /user/clinical/staticreportpath
Returns:
N/A
Syntax:
JMPClinicalReviewAPI:createStaticReport = function({type = empty(), includeNotes = empty(), filePath = empty()}, {default local},
JMPClinicalReviewAPI:createLiveReport
Creates a web-based JMP Live version of the review.
Arguments:
{ConnectionName = String} - specifies the name of the JMP Live Connection
{Space = String} - specifies the name of the JMP Live Space to publish to, within the JMP Live Connection
{PublishData = Number} - type 1 to allow data to be published, 0 to disallow it
{PublishOptimization = Number} - type 1 for best interactivity, 2 for best performance
{AllowDataToBeDownloaded = Number}: type 1 to allow data to be downloaded, 0 to disallow it
{PublishNotes => Number} - type 1 to include notes, 0 to not include notes
Syntax:
JMPClinicalReviewAPI:createLiveReport = function({ConnectionName = empty(), Space = empty(), PublishData = empty(), PublishOptimization = empty(), AllowDataToBeDownloaded = empty(), PublishNotes = empty()}, {default local},
JMPClinicalReviewAPI:upgradeReviewTemplate
Reads a single review template (infile) and writes its upgraded form (outfile).
Arguments:
{infile} - The path to a review template created in an older version of JMP Clinical
{outfile} - The path to the destination of the upgraded template
Returns :
N/A, but diagnostic information is written to the JMP log.
Syntax:
JMPClinicalReviewAPI:upgradeReviewTemplate = Function({infile, outfile},
JMPClinicalReviewAPI:upgradeReviewTemplates
Reads all review templates from a directory (infolder) and writes their upgraded copies to another directory (outfolder).
Arguments:
{infolder} - The path to a source directory containing review templates created in an older version of JMP Clinical
{outfolder} - The path to a destination directory where upgraded review templates should be written
Returns :
Syntax:
JMPClinicalReviewAPI:upgradeReviewTemplates = Function({infolder, outfolder},
