Available Reports
Reports are grouped into functional categories, as listed below:
Subject Level
Reports using data from across multiple domains are described in the table below:.
Report |
Choose this report for... |
Study Flow Diagram |
Generates a flow diagram to summarize the overall clinical trial data flow. |
Patient Profiles |
Profiling subjects is a powerful way to view all of the data for one or more subjects, enabling you to view their entire history and determine potential causes for unexpected events or findings. |
Compares distributions of demographic variables across treatment arms via a one-way ANOVA or contingency analysis. |
Generating a graphical display and tabulation of study visit attendance. |
Adding data for various domains to the ADSL table corresponding to incidence of variables in the AE, CM, LB, and MH domains and a summary statistic for LB, EG, and VS domain values |
Adverse Events
Reports examining patient study events are described in the table below:
Report |
Comparing Distributions of adverse events and demographic variables across treatment arms for single occurrences of the events. |
Comparing Distributions of adverse events and demographic variables across treatment armsfor multiple occurrences of the events. |
Adverse Events Incidence Rates
Tabulating the number of occurrences of each event and calculating their incidence rates. |
Generating adverse event narratives for clinical study reports |
Adverse Events Time to Event
Screens all adverse eventsby performing log-rank and Wilcoxon tests between treatment groups. The time to first occurrence of the adverse event is used as the response. |
Screening all adverse eventsand calculates and generates forest plots of risk differences, relative risks or odds ratios |
Medical Query Risk Report
Screens medical query terms by performing Cochran-Mantel-Haenszel (CMH) tests on all 2 x 2 tables constructed from event incidence and treatment arm. Output is a two-sided plot with a dot plot showing percent occurrence and forest plot showing risk measurement. |
Algorithmic FDA Medical Query Risk Report
This process uses FMQs with associated algorithms together with data from DMSEX to query AE, LB, and CM for subjects meeting the specified qualifications and the performs Cochran-Mantel-Haenszel (CMH) tests on all 2 x 2 tables constructed from event incidence and treatment arm. Output is a two-sided plot with a dot plot showing percent occurrence and forest plot showing risk measurement along with a table listing number (and percentage) of subjects exhibiting each FMQ by specific qualification. |
Custom Medical Query Risk Report
Calculates risk measurements for custom medical queries defined in the adverse events dataset. |
Creating a tabular and graphical overview of treatment emergent adverse events for the safety population by actual treatment arm |
Other Events
Report |
Clinical Events Distribution
Capturing clinical events specially tracked as being of interest to the particular study and reported in the CE domain. |
Comparing Distributions of events from a domain and demographic variables across treatment arms for single occurrences of the events. Note: This report should be considered as two: DS Distribution and MH Distribution, depending on which domain is specified in the dialog. |
Comparing Distributions of events from a domain and demographic variables across treatment arms for multiple occurrences of the events. Note: This report should be considered as two: DS Distribution and MH Distribution, depending on which domain is specified in the dialog. |
Screening all events from the specified domain and calculates and generates forest plots of risk differences, relative risks or odds ratios Note: This report should be considered as two: DS Risk Report and MH Risk Report, depending on which domain is specified in the dialog. |
Grouping clinical mortality results by treatment arm and generating Kaplan-MeierSurvival Curves with associated statistics |
Creating Kaplan-MeierSurvival Curves for time to study discontinuation and associated statistics, grouped by treatment arm |
Disposition Distribution
Comparing Distributions of dispositions across treatment arms with associated risk differences. |
Interventions
Reports describing interventions are described in the table below:
Report |
Generating an exposure summary and plot for all subjects in a study of an investigational product, by dose and exposure time for the safety population, by treatment |
Comparing Distributions of interventions and demographic variables across treatment arms for single occurrences. |
Comparing Distributions of interventions and demographic variables across treatment arms for multiple occurrences. |
Screening all interventions and calculates and generates forest plots of risk differences, relative risks or odds ratios |
Findings
Reports examining patient findings are described in the table below:.
Report |
| Acute Kidney Injury | This report assesses the results of multiple lab tests enabling you to determine whether trial subjects have sustained acute kidney injury as a result of receiving the trial drug. Analysis results are presented and summarized in multiple graphs and tables. |
Drug-induced Liver Injury |
This report assesses the results of multiple lab tests enabling you to determine whether trial subjects have sustained drug-induced liver damage. Analysis results are presented and summarized in multiple graphs and tables. |
Displaying Box Plots by treatment group representing the change from baseline in measurements for each test for a specified findings domain across various time windows or points in a study |
Comparing Distributions of findings and demographic variables across treatment arms |
Findings Mean Change from Baseline Tables
Listing the number (and percentage) of patients in each treatment arm at each visit for each specified test and then calculating the mean change from baseline for all patients in each group. |
Displaying Shift Plots to compare test measurements for a specified findings domain at baseline versus on-therapy values, and performing a matched pairs analysis on average score during baseline and a summary score during the trial |
Findings Shift Tables
Collecting all of the specified findings test results and constructing a table listing the number (and percentage) of subjects in each treatment arm that are considered high, normal, or low for each test, grouped by visit. |
Findings Time Trends
Enables you to visualize findings measurements across the time line of the study. |
Creating waterfall plots to show the distribution of changes in test measurements for a given Findings domain across subjects |
Visualizing peak values for lab measurements pertaining to Hy’s Law for detecting potential liver toxicity for all subjects across treatment arms |
Oncology1
Reports are described in the table below:
Report |
This process creates a disease response swimmer plot and tables around either the best or last recorded response rates and calculated objective response rate for solid tumor oncology clinical trials. The results of these assessments are summarized based on selecting either the Best response per subject, based on preferred order: CR, PR, SD, PD for controlled terms, respectively, or Last recorded response. The objective response rate (the sum and percentage of subjects who had CR + PR assessment result) is also calculated and listed in the summary table. |
Progression free survival is used to describe how long patients can go without the disease without getting worse. This process uses a modified survival plot and hazard ratio plot to compare the number and percentage of patients who have tumor progression or death, with patients who show no tumor progression or death at the cut-off date. |
Tumor Response |
This process uses the TR, TU (optional), and RS (optional) oncology domains to create spider plots showing tumor results and waterfall plots showing Best or Last recorded responses. |
Reports
Report |
DSUR/PSUR Report
Generating a report for updating regulatory agencies regarding the safety of a clinical trial design and execution for the purpose of securing permission for the continuance of the trial. |
Generating a document of study comments obtained from source data pertaining to each subject. |
Data Quality
Report |
Birthdays and Initials |
Attempts to identify subjects, by their birthdays or initials, who register at multiple study sites. |
Cluster Subjects Across Study Sites |
This report is used to identify similar subjects within a demographic subgroup, such as Sex = F and Race = Asian. It does so by constructing a cross domain dataset using as much baseline data as possible (subject to user options). The goal of this exercise is to identify pairs of subjects with a very small distance. This could be an indication that these subjects are in fact the same individual who has enrolled at multiple sites. |
Cluster Subjects Within Study Sites |
This report clusters subjects within study site for the purpose of identifying similar subjects. It constructs a cross domain data set using as much baseline data as possible (subject to user options). The goal of this exercise is to identify pairs of subjects with a very small distance. This could be an indication that these subject are slightly modified copies of one another. |
Identifying tests from findings domains that have the same result for the entire study |
Assesses the use of terminal digits by study sites when reporting their clinical findings to identify those sites that might exhibit biases in rounding issues or other problems with how they report data. |
Identifying sets of records that have identical values on more than one occasion within a subject or between subjects within a study site |
Determines whether individuals are missing data for all test codes across all Findings domains, based on data available at each visit number and time point number. |
Calculating Mahalanobis distance based on available data to detect subject inliers and outliers in multivariate space, and generating results by site to see which sites are extreme. |
Identifies outliers and identifies sites with excessive outliers.
Patient Recruitment
This report estimates the likelihood that recruitment goals are met using enrollment data collected so far. The estimated parameters are then used to predict future enrollment patterns given the existing number of study centers and the number of new centers necessary for the target enrollment to be reached by the deadline. |
Perfect Scheduled Attendance |
This report compares the distribution of study visit days for each center compared to all other centers combined, and identifies unusual differences. |
Risk Based Monitoring |
Risk-based monitoring is a proactive method of clinical trial monitoring to detect patient safety risks and data quality issues at an early stage of a trial. |
Visit Order |
Determines whether visit dates are unusual for subjects when ordering dates according to visit number. |
