Group Level
Use this option to specify the level for grouping preferred terms or verbatim terms.
Possible group levels are listed in the following table:
Group Level1 |
Corresponding Variable |
Function |
Body System |
AEBODSYS in AE |
Higher Level Term (HLT) |
AEHLT in AE |
Higher Level Group Term (HLGT) |
AEHLGT in AE |
Standard MedDRA Query |
Primary System Organ Class (SOC) |
AESOC in AE |
Lowest Level Term (LLT) |
AELLT in AE |
Body System or Organ Class |
AEBODSYS in AE |
Dictionary-Derived Term |
AEDECOD in AE |
Reported Term for the Adverse Event |
AETERM in AE |
Category |
CMCAT in CM, or SUCAT in SU |
Category for Medication |
Note: The dictionary name and version used to generate the descriptions should be included as part of the submission.
Note: In some reports, options are dynamically populated by available terms (with the list available filtered based only on hierarchically sensible grouping choices).
To Specify the Group Level:
| 8 | Select the group level corresponding to the adverse event or intervention terms that you want to use from the drop-down menu. |
