Refer to findings tests using:
Use this option to choose whether to refer to findings results by code (xxTESTCD) or full name (xxTEST) in the narrative, where xx is either EG, LB, or VS, depending on the specified findings domain.
• Select Test code to refer to the labs as specified by the xxTESTCD column.
• Select Test name to refer to the labs as specified in the xxTEST column.
To Specify This Option:
8 Make sure that the Include a findings domain in the narrative box is checked.
8 Click the desired radio button.
