JMP Clinical Configuration Qualification Tool
This add-in enables you to inspect the active configuration’s paths and verify whether they are correct for the current user.
The Configuration Qualification tool tests six different configuration factors:
1 Are the expected keys present?
2 Do the keys have values and do those values map to unique directories on the user's hard drive?
3 Do the non-writable folders laid down by the JMP Clinical installer map to readable locations within the /install/ directory?
4 Do the writable folders, created when JMP Clinical is first opened, map to writable locations within the /user/ directory?
5 Do the study-specific files/folders exist and map to study-specific directories?
6 Do the study-specific files/folders for all available studies exist and map to writable directories specific to their respective studies?
Installing the JMP Clinical Configuration Qualification add-in
This add-in is included in JMP Clinical. You must, however, install the add-in before you can use it.
8 Navigate into the Addins folder (C:\ProgramData\JMP\JMPClinical\19\Clinical\Addins).
8 Locate the JMPClinicalConfigurationQualification.jmpaddin file and drag it onto an open JMP Clinical window.
8 When prompted to install the add-in, click OK.
The add-in installs automatically.
Using the JMP Clinical Configuration Qualification Tool
8 To access this tool, click on the JMP Clinical Main Window to open the JMP Home Window.
8 Click Add-Ins > JMP Clinical Configuration Qualification to open the tool.
8 All 6 tests are selected by default. Click the appropriate check box to deselect undesired tests.
8 Click to run the tests.
Configuration Qualification Results
When you click , the tool runs the selected tests and generates a results window.
Note that the current configuration passes all qualifying tests for the selected study.
