Findings
The Findings field is an optional parameter that enables you to filter rows from the specified Findings data set (EG, LB, or VS) to choose the appropriate records to subset to findings of interest. Risk indicators are calculated using this subset only.
This filter uses JMP WHERE clauses to Select Rows that meet the specified criteria. To use this filter, you must enter the JSL (JMP Scripting Language) expressions that constitute the WHERE clause in the appropriate text box for specific filtering of findings. Note: This is an advanced concept that not only requires some basic knowledge of the JSL where clause syntax (similar to, but different from, SQL), but also an understanding of the exact variables in the tables in the study.
To specify a Findings filter:
8 Click to open the WHERE Clause Builder to construct the desired filter.
8 Click to clear the filter.
