Findings Domain to Analyze
Use the drop-down menu to select the findings domain to specify the ADaM or SDTM data set to use in the analysis. Your choices include Laboratory results (LB), Electrocardiogram results (EG), and Vital Signs (VS).
For example, to produce analysis for lab test measurements, you would select the LB domain to use either the lb.sas7bdat data set or adlb.sas7bdat data set for computation. Domain names can contain up to 8 characters. ADaM data sets can be up to 8 characters, but only if the first two letters in the name are AD.
Note: If using the Filter to Include Findings Tests parameter to run analyses only on specified domain tests, the notation used for the WHERE statement there must match the choice of domain made here.
To Specify the Findings Domain to Analyze:
8 Make a selection using the drop-down menu.
