Group Level
Use this option to specify the level for grouping preferred terms or verbatim terms.
Possible group levels are listed in the following table:
Group Level1
Corresponding Variable
Function
Body System
AEBODSYS in AE
Uses a dictionary-derived text description of the affected body system, listed in the AEBODSYS column in AE.
Higher Level Term (HLT)
AEHLT in AE
A superordinate descriptor for multiple preferred terms (PTs).
Higher Level Group Term (HLGT)
AEHLGT in AE
A superordinate descriptor for multiple higher level terms (HLTs)
Standard MedDRA Query
Grouping of MedDRA terms, at a defined level, that describes a specific medical condition.
Primary System Organ Class (SOC)
AESOC in AE
Uses Primary System Organ Class level of adverse events as categories.
Lowest Level Term (LLT)
AELLT in AE
Uses Lowest Level Term level of adverse events as categories.
Body System or Organ Class
AEBODSYS in AE
Uses body system or Organ Class level of adverse events as categories.
Dictionary-Derived Term
AEDECOD in AE
Uses Dictionary-Derived Term level of adverse events as categories.
Reported Term for the Adverse Event
AETERM in AE
Uses Reported Term for the Adverse Event level of adverse events as categories.
Category
CMCAT in CM, or SUCAT in SU
Uses Category level of interventions as categories.
Category for Medication
Note: The dictionary name and version used to generate the descriptions should be included as part of the submission.
Note: In some reports, options are dynamically populated by available terms (with the list available filtered based only on hierarchically sensible grouping choices).
To Specify the Group Level:
8 Select the group level corresponding to the adverse event or intervention terms that you want to use from the drop-down menu.
