Set reference line for bilirubin
Use this option to specify a custom reference line for the bilirubin test (BILI) and alkaline phosphatase test (ALP) to be drawn on the Hy’s Law plot.
Note: This same custom threshold is used for both BILI and ALP.
To Set a Reference Line for Bilirubin:
8 Check the Set custom reference lines for Hy’s Law plots box to enable this option.
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
