Set reference line for x-axis
Use this option to specify a custom reference line to be drawn on the Bubble Plot.
Lines are set for each domain as described in the following table:
Domain
Equivalent to:
LB
Lab measurements are automatically standardized by the LLN and ULN such that the line is drawn at k*ULN of the x-axis lab test, where k is the integer chosen in this field.
EG
Electrocardiogram measurements are plotted on their original scale.
VS
Vital signs measurements are plotted on their original scale.
To Set a Reference Line for the x-Axis of the Bubble Plot:
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
