x-Axis for Volcano Plot
Use this drop-down menu to specify the statistic to use on the x-axis of the output Volcano Plots.
Choose:
When you want to:
Risk Difference
Use the difference in estimated proportions.
log2(Relative Risk)
Use the ratio of the proportions of occurrences on a log2 scale. so that a unit change corresponds to a doubling
log2(Odds Ratio)
Use the ratio of the odds of occurrence between two groups on the log2 scale. The Woolf-Haldane estimate of the Odds Ratio is used if any of the table cells are equal to 0.
Note: For rare events (occurrences), the odds ratio approximates the relative risk
To Specify the Statistic to Plot on x-Axis of the Volcano Plots:
8 Use the drop-down menu to select the desired statistic.
