Remove variables from analysis with a missing data percentage of at least:
For each variable, if the percentage of missing data for the selected population (including WHERE statements and filters) equals or exceeds this threshold, the variable is excluded from the analysis.
To Specify the Minimum Missing Data Percentage for Exclusion:
8 Ensure that the Remove all variables with missing values box is not checked.
8 Either enter the desired value in the text field or move the slider to the right or to the left to change the value.
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
