Perform incidence analysis using the following SMQs:
Use this feature to specify how the incidence analysis is to be performed.
Available options are listed in the following table:
Option
Description
Narrow search at the individual SMQ level
Performs an analysis of narrow SMQs terms. For hierarchical SMQs, does not consider any sub-SMQs that might be a part of the SMQ when calculating incidence.
Broad search at the individual SMQ level
Performs an analysis of broad SMQ terms. For hierarchical SMQs, does not consider any sub-SMQs that might be a part of the SMQ when calculating incidence.
Narrow search cumulative for level 1 SMQs
Performs an analysis of narrow SMQ terms. For hierarchical SMQs, reports only the level 1 SMQs and includes all sub-SMQs when calculating incidence.
Broad search cumulative for level 1 SMQs
Performs an analysis of broad SMQ terms. For hierarchical SMQs, reports only the level 1 SMQs and includes all sub-SMQs when calculating incidence.
Algorithm SMQs only
Performs an analysis of SMQs that have an algorithm as part of the definition.
Note: There are a very limited number of SMQs with algorithms.
To Specify the Type of Analysis:
8 Click within the appropriate radio button.
