Summary Statistic to Compute Within Time Windows or Visits
Select the statistic by which to summarize the measurements for each subject within each time .
Options are defined in the following table:
Summary Statistic |
Definition |
Min |
Mean |
Median |
Max |
If no time s are used (None is selected for Time Window Method), then box plots for the Max, Mean, Median, and Min values for each subject across the entire trial are displayed for each Findings test.
When time s are used (something other than None is selected for Time Window Method), a box plot for the selected statistic is displayed for each time (or point), as well as box plots for the Min and Max values for each subject across the entire trial.
To Specify the Summary Statistic:
| 8 | Click the radio button corresponding to the summary statistic that you want to use. |
