Display symmetrical axes for Shift Plots
Check this box to force the X axis and Y axis of each Findings test shift plot to have the same minimum and maximum values.
When this box is checked, the 45° line for each finding, that indicates no change between baseline and trial values, align in the graphic. Points falling above the line indicate an elevation compared to baseline (Note: This is true regardless if this option is checked).
To Specify This Option:
| 8 | Check the box. |
